Valid points there about replacing, or if you have room and wish to see how these get on, plant another couple nearby, you can take out the wounded trees anytime, and they may well surprise you..
Yeah, I have plenty room.Valid points there about replacing, or if you have room and wish to see how these get on, plant another couple nearby, you can take out the wounded trees anytime, and they may well surprise you..
I agree, will leave it up. Will just add more when I see them.Even though I spend my days climbing and cutting trees, mostly to negate litigation, I am a bit of a conservationist at heart, as long as it doesn't compound issues later.
Thanks, yes he is a ballsie buck. Probably my fault for putting a feeder in the front yard. He has tons of trees to tear up, but he hit my only 2 chestnuts that where not protected.Geoff spends his days cutting them, and I have a BS in Forestry and Biology, so marking them for cutting/sale is my background.
I think Geoff will agree that if they aren't going to respond well, you're going to know within 2-3 years, tops. Then you can remove/add if warranted. Wouldn't give up just yet either.
Still amazed happened in front yard....at least mine got stripped 100' out back.....ballsie buck!
That feeder is the one I watch when I come in between morning hunts and afternoon hunts. If I see a legal buck there he is toast.Helo- Ahhh, feeder in the front yard! Note to self: Don’t do that again.
if it makes you feel any better, just saw another of my Frasiers are beat to hell out back. Haven’t looked closely yet, but looks like a little guy got frisky...
Only had a few left....and I planted 100 first fall at the house 26 years ago. [emoji31]
Like they said above though. I have plenty room, so I can plant as many as I want. No real reason to take them down. Worse case they die, if not they will at least be shade trees.As bad as it looks I'd take them out and replace them with healthy trees. Even if they do recover, it'll be years.
Thank you, will try that on some trees.I put this on a similar post. It s a common way municipalities do it.
Get some wrinkled corrugated plastic pipe thin walled 4" or 6" diam. and slice it lengthwise and put it around the trunk. Won't hurt the tree and can last as long as you need the protection. Black may not show as much as white color. I have found it works great.
Yes, wonder why they only like the trees I planted. 64 acres of other trees and they hit these.Helo - looked at my fraser fir rubbed up by the buck - pretty beat...one have 2 or 3 left now......
Will get a picture, but little tree rubbed up low, tells me a little buck...
