Today I removed the cowling so I could replace some fuel lines and fuel filter and do some general checking on the tractor.
After getting the fuel filter and lines replaced, I go to bump the starter and bleed the air out of the lines and..... nothing. I can hear the starter relay clicking.
I pulled my truck up to see if the battery needed a jump. No help.
I tested the starter relay, neutral safety switch, and starter. All seem to be working. Power is being sent to the starter, but it won't crank. Nadda.
Is there some magic switch somewhere that gets tripped when you remove the cowling? This thing ran (albeit for only 15 mins) last week. Now it won't even crank the starter???
