BX2370 blowing 50amp fuse
mdkeener75
Blountstown, Florida
Does anyone have any idea what would cause the 50amp fuse to blow when trying to start the tractor? It is less than a year old and has about 70 hrs on it? When I replace the fuse and turn it to accessory it is ok but when I actually try to start it it blows the fuse. I have checked the wiring at the starter, alternator, and the battery, I see no bare wire or anything that might be shorted. Could the ignition switch be bad? Would a bad starter cause it? Any help would be appreciated.
2,551
Have you checked for rat damage? They can eat away at insulation and create havoc!!!
YOU have a positive hitting a ground somewhere once the starter is engaged.
OLD GAR
MF210, FORD 8N, BIG TEX CH18,
Aug 3, 2015
69
ZWOLLE
50 amp! What is fused with that beast? As 85Hokie say you may have a bare wire from the ignition to the starter. Another likely cause is the starter bearings are letting the armature drag and pulling an overload.
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Lift the small start wire from the starter solenoid and try again, if it doesn't blow, then you have a fault in the starter/solenoid, if it still blows, track the wire back to the switch.
