Hey folks, I recently purchased a B7001 4WD Kubota and when I got it home and really started looking into the tractor, I noticed quite a few problems that the previous owner neglected to tell me. I discovered the that all the original electrical wiring had been removed and new hacked in wiring installed. The original ignition switch was replaced with an after market switch from who knows where. The glow plugs didn't work so I replaced them and still no go. The ignition switch is wired so that the glow plugs don't get power until you turn the key to the "Start" position and consequently, the tractor is difficult to start. I think I'll replace the ignition switch with a Kubota switch and route new wiring and hopefully this will fix the glow plug issue. Finally, I noticed my tractor was leaking diesel fuel at the fuel bowl due to a crack in the plastic. I'm having a hard time finding a replacement bowl for a B7001 with a D750 engine. Does anyone know where I can find one?
