L2200 Axle seal part number?
Lblevins
Kubota L2200, John Deere 1050, Kubota L3301 with woods bh80x
Sep 1, 2017
Ada, ok, USA
Look's like my right rear axle seal has completely gone out and pouring, It is a grey market tractor does anyone know apart number for seal tried getting one for a l225 (34150-27560) and it is a twopiece seal but is wrong sizes. Any help guys? I am at a loss and have tractor torn down in front of my shop.
Lblevins
Sep 1, 2017
Ada, ok, USA
I am completely stumped on this as it has a collar and a seal like a L200/L210.
9,725
If you would post up some pictures of the seal and the axle assembly and we'll see if we can come up with anything. ;)
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
Looks like there is NOT a US equivalent tom the 2200
But the L2201 is similar to the L245, possibly a long-shot,
but as NIW said "pictures"
Lblevins
Sep 1, 2017
Ada, ok, USA
It looks exactly like a l225 but the l225 seal is too small. it looks the same just too small. Somebody told me to order one for a l260 cause it is the same but larger so I guess that's the next guessing game. Thinking about just putting a speedi sleeve on axle and a 56x80x13 oil seal in it and calling it good. I mean that should work right. axle shaft is 56.8mm and housing is 79.7mm and I can go as deep as 18mm on seal width.
Lblevins
Sep 1, 2017
Ada, ok, USA
Well here is what I am thinking of doing. the shaft is 56.8mm and housing is 79.7 x 18mm wide so the local parts store has two 56x80x8mm seals. I think just clean axle shaft smoothly with some 2k grit and run both seals straight on the axle. Tractor will never seen brush hog or much of anything other than a grading blade for drive and yard and a front loader im going to build to move dirt. What do you guys think?
8,830
If you have enough space to put two of those lip seals, the inside one put the spring towards the oil. Outer one, spring towards the wheel. Then you get the best of both worlds. Inside one keeps the.oil from coming out. Outside one prevents trash from coming in
Sent from my SM-G920R6 using Tapatalk
Lblevins
Sep 1, 2017
Ada, ok, USA
That is what I was thinking/hoping would be my best bet.
Lblevins
Sep 1, 2017
Ada, ok, USA
well it is fixed and works well. Had 18mm of gap and put two 9mm seals in without a collar and no problems and works great.
