al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
So my new to me b1750 will be coming home this coming Saturday,I know it has a tranny issue,gets weak after about 20 minutes of use. In the mean time I've decided to scrap my g2000. I have already put a pto idler and two new pto belts on it this year,and due to wear in the pto those belt are done already. Then the starter went,that was the final straw. Has other known issues.So as a prequel to the b1750 I decided to crack open the hydrostatic on the g2000. A couple observations,first they are deceptively simple internally compared to a engine. Second,a couple of things I noticed has led me to believe Kubota reworks there castings and parts for several applications. This hydro casing had castings for a top filter that was left un machined and was simply capped off.also had a splined shaft that was sleeved over with rubber and not used.
