Unknown warning light on X1120D
HandlebarFarm
South Carolina USA
We've had an X1120D for several years now and have never had any prior problems with it.
On Thursday my Dad shifted it into 4WD and a warning light lit up on the dashboard. We can't figure out what it means. It's right next to the 4WD indicator light as shown in the pictures below.
After researching the manual and the web without success, we inquired at the Kubota dealership. They didn't know the answer either.
Any input you can offer would be greatly appreciated.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
That symbol usually goes on when the pto is engaged in most tractors. Any chance he bumped that lever?
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
So there is no information about that light on page 22 of the manual?
HandlebarFarm
South Carolina USA
I posted last week with a question regarding this PTO warning light issue. I thought I'd follow up here to let everyone know what the final resolution was.
Apparently Kubota uses a single dashboard panel design and wiring harness for multiple RTV models including those without the PTO feature.
In the control box where the 4WD shift handle is attached there is a series of wiring connectors. The 4WD and PTO indicator connections are right next to one another and this sometimes causes the electrical current to jump from one to another if they're too close.
The Kubota dealer used to needle nose pliers to add some space between those connectors in order to resolve this problem.
9,680
Thanks for the follow up, good information to know! ;)
