Internal lathe threading
Yooper
3901 LA525
May 31, 2015
1,745
924
NE Wisconsin
Made a threading tool out of a large tap to thread a hex nut. My internal threading tooling is pretty lame so after going through my drawers I came up with the idea for this tool. I just ground off all the teeth except the first one and then mounted it on a QC boring bar holder. Did a passable job. Thought I'd pass this on to the other lathe owners out there.
twomany
B7200
Jul 10, 2017
793
139
Vermont
Resouceful!
I might have left all the teeth on the flute, and taper ground the first four to give a progressive cut.
11,093
Excellent, filing that away for future use. ;)
3,547
Nice! When teaching new machinists, one of the hardest things to convince them was that there are no hard & fast "one way only" rules. Got to think out of the box occasionally.
twomany
B7200
Jul 10, 2017
793
139
Vermont
That would only work if you were threading the same tpi as the tap.
Somehow I thought the threads looked "mighty close". Just different diameters.
Must be the camera angle ;-)
Practically, I keep a selection of internal threading tools on hand. Biggest headache is swapping tools between QC tool holders. Three lathes, three different size QC tool posts, and it always seems the last time the desired threading tool was used, it was on one of the other machines. ;-)
7,659
See, that's the problem...."twomany"!:D:D
Tooljunkie
May 13, 2014
4,150
35
My one and only south bend is almost as rigid as a wet noodle,so any advantage for threading is a bonus. I had a collection of old taps given to me,so experimenting with them wont seem so wasteful.
Yooper
3901 LA525
May 31, 2015
1,745
924
NE Wisconsin
Mind my asking what your favorite set up is? Time to get me some real tooling.
npalen
B9200
Feb 10, 2016
Beloit, KS
I'm wondering how much difference in thread pitch would be a problem due to the helix angle on the tap. Just asking.
Yooper
3901 LA525
May 31, 2015
1,745
924
NE Wisconsin
That is an issue with this method. You could grind some of the tooth under the cutting edge to help a bit. This is just to get you out of a jam like I was in.
Would still like to hear from some of you fellow lathe owners what you like to use for single point internal threading.
