Thanks Kenny,
I see there are some Light weight fork options out there,But Ihave not found any for the new SS. type QA, I did see Ai2 is working on one for the new QA system.
https://bxattachments.com/sneak-pea...et-forks-for-the-new-skid-loader-quick-hitch/
But Im in hawaii so everytjing is trickyer to have delivered. So im leaning toward the dealer option which they list in their specs as total frame and fork weight as 274 lb and they say total lift capacity is 242 lbs, that seems low? See specs below.
What does everyone think about that 242 number
These are the spec from kubota on the frame and forks that ship with the 2017 BX23S for the SSQA system:
On Monday, July 17, 2017 12:35 PM, KTC Customer Satisfaction <ktc_g.customersatisfaction@kubota.com> wrote:
K9184 Pallet Fork Dimensions:
overall length (assembled)--in (mm):
overall width--in (mm): Frame- 41 (1041)
overall height--in (mm): Fork- 21.5 (546) Frame- 28.5 (724)
effective fork length--in (mm): 32 (812)
fork width--in (mm): 3.94 (100)
BX2415 Pallet Fork Frame Dimensions:
overall width--in (mm): Frame- 45 (1155)
overall height--in (mm): Fork- 21.5 (546) Frame- 29 (739)
fork thickness--in (mm): 1.57 (40)
fork width adjustment (fork center line)--in (mm): 20.25 (514.35)
weight of each spring fork--lbs (kg): 84 (38)
weight of frame only--lbs (kg): 107 (48.4)
weight of pallet forks (complete)--lbs (kg): 274.8 (124.6)
pallet fork rated lift capacity--lbs (kg): 242 (110)
