Hydraulic help
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
Hello everyone, I'm new here to the forum and also new to the tractor world. I have a new 2017 L2501 with LA525 FEL, landpride FDR1672 mower and a Buhler Farm King 500 snowblower. I was actualy wanting a skid steer of some sort because I didn't know much about tractors, but my father inlaw, being a farmer, convinced quite quickly how handy a tractor would be when he GAVE me the above unit. Needless to say I was extremly excited and still am. It is going to come in real handy on my small acerage. I never realized how handy the 3 point hitch will be as well as the PTO. The FEL has the quick attach skid steer mount so I have been looking at all the stuff that I would like to have. That being said, it brings me to my question. Let me just say first off that I know very little about hydraulics, but I am learning. I would like to add a set of remote hydraulics to the FEL as well as to the rear of the tractor for any possible impements I might aquire. I will never be using the front remote and the back remote at the same time so I was thinking of installing one operating control valve and a diverter to switch from the front to the back. Would this work. I have done a ton of research on tying in the new control valve into the existing FEL hydraulics, so I think I have that figured out. I'm just unclear of where to go from here. Would I come out of the pressure port on the new valve to the diverter, then from the one port on the diverter to the front and the other to the back. Is this correct. Would I actually need a diverter valve being that I am using only one of the remotes at a time. Sorry for all the questions, just trying to learn.
Tooljunkie
May 13, 2014
4,150
Wouldnt need a valvle to select front or rear, whatever is connected will work.just dint have two implements connected to remotes at same time. T's are cheap, selector valves are not.
Stomper
Jun 30, 2017
240
Northern Canada
Thinking some more on this, my main reason for adding remotes is for firewood processing and I want to add a grapple on my bucket for logs and use the rear for a log slitter. I don't want to have to disconnect the grapple every time I use the log splitter so I will have to install a diverter valve. Just for clarification, this is what I THINK I have to do. Be gentle on me as I am new to hydraulics.
1. Remove the power beyond hose on the existing FEL valve. "BY" port.
2. Run a line from this power beyond "BY" port to the pressure "P" port on the new control valve.
3 Hook the existing power beyond line to the power beyond "BY" port on the new control valve.
4. From the two working "A" and "B" ports on the new control valve, run 2 lines to the two in ports of the diverter valve.
5. From each of the two out ports on the diverter valve, run two line to the front and the rear of the tractor.
For the control valve I will need a tandom center valve, so that the "A" and "B" ports are blocked and the "P" and "T" ports are open (connected) while in the center position. Correct.
Does this sound correct or am I misunderstanding something
6,618
Log splitters on that tractors hydraulics is going to be incredibly slow, just so you know. ;)
Stomper
Jun 30, 2017
240
Northern Canada
I was hoping it would be the same speed as it is right now. It only has a 2" bore on the cylinder. I run the splitter now with my hydraulic pack for my tube bender and it splits 16" logs as long as they don't have to many knots. Time will tell. Thanks for the reply
5,239
1,022
Running your splitter with an expensive tractor engine is just putting needless hours on it when, for few hundred $, you can buy a gas engine and 2 stage pump which will be much faster and more convenient.
A rear remote valve from Kubota will be near $1,000 if you lived in Canada.
Dave M7040
Stomper
Jun 30, 2017
240
Northern Canada
Good point about the hours on the tractor. I think I'll stick with what I am doing now. Thanks for the insight guys. I'm still going to put on rear remoter so my options are still available for attachments
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Do a search for 3rd function valves. That's what the valve to control the grapple is called. Typically they're mounted on the loader.
I'd use a separate valve inline for the rears instead of having a diverter to switch between front and rear.
