Grand L60 - L6060 HST
tractorfan17
northeast
Hi, I am considering buying L6060 HST. I can't find anywhere the exact height with the ROPS folded.
Does anyone out there has or knows the height of L6060 with the ROPS folded?
I want to know if it can fit through my garage door.
Thank you very much.
Ron L4760
53
Johnson City TX
There's lots of spec sites out there the double check and verify it, but anecdotally my L4760 with Rops UP and added canopy goes under a 10' door with about 8" clearance.
tractorfan17
northeast
Ron, I tried to find the exact height with the ROPS folded. I couldn't find it anywhere. Perhaps you can direct me to the right websites where I can find or ask that question.
My garage door is 6'10"...so I don't know if L6060 (or any other grand L60) can fit with the ROPS folded.
sheepfarmer
Nov 14, 2014
4,449
677
MidMichigan
The specs for the 6060 show that there is only 2 cm increase in height with the rops up over my 3560, so later today I'll measure the rops folded height on mine to give you a ballpark idea.
jryser
427
Plainfield
You beat me to it Sheepfarmer! I'll measure mine too just for good measure. Wow. I just said that. [emoji12]
L4060
10
Rayne, LA, USA
My garage door is 7 foot and my L4060 clears by a 1/2 inch with the ROPs down, if I have the backhoe on it clears it by 2 inches. So I would say you will be cutting it really close. I have R4 tires.
tractorfan17
northeast
Thank you sheepfarmer, jryser, and L4060.
Based on the information L4060 just gave, I think height is doable...here is how:
Your R4 tires are 50" high which means impossible for me to drive through the 6'10" (82") door...because it takes 83.5" total height.
But, if I use R3 tires instead, then the tires are 44" high and that is good enough to bring down total height to 80.5". 1.5" is plenty of room.
Now what about the length of tractor with the loader (LA1055) and backhoe BH92? how deep does the garage need to be fit and close door?
Thank you.
L4060
10
Rayne, LA, USA
Thank you.
It's about 22.5 ' with the backhoe on, I have 24' deep garage and it fits fine. You could always turn the backhoe to the side if you don't have enough depth. I was worried about the same things, I was really sweating the height but it worked out ok. I have to lower the backhoe down when bringing it through the door because it sticks up pretty high, but that hasn't been a problem.
tractorfan17
northeast
Thank you very much L4060, you've been extremely helpful.
One last question, do you have LA805 or LA1055 loader?
And how is the horsepower on your tractor? Do you feel it is more than enough for the different implements?
Thank you
L4060
10
Rayne, LA, USA
Thank you
It's a LA805 FEL, so far it has plenty of power for what I do which is mowing and digging and a little FEL work moving dirt around. I'm probably just going to leave the backhoe on since I kept the old L3430 for mowing. What I really like is the fuel usage, it's been using 1/2 gallon per hour no matter what I'm doing mowing or digging. The l3430 seems to be closer to a gallon per hour.
