NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
I was in the market for a side by side.
I'll be using mine primarily for hauling firewood through the woods. I looked around at numerous trailers. It was tough choice deciding on what to pick but I ended up going for a polar hd 1500. It was a poly version, not unlike the mini 10 cubic foot JD trailer I have. I figured lightweight, easy to maneuver...It was a mistake. Most stores don't have display models and it wasnt till I put it together that I realized it was much too wide. The information on the website didn't have the correct specs and it was just over 60" wide. Too wide for my storage shed. So back it went. I ended up set tingling for a JD 1,650 lb. 18 cu. ft. Tow-Behind Steel Utility Cart.
I looked at several different manufacturers. Kubota, John Deere, Honda. Kawsaki, Can Am, Polaris.
In my situation I need clearance, maneuverability, and a high tow rating. Finding a good dealership was the first priority. If I couldn't find a good shop to work with I would be reliving some unpleasant experiences I had.
Most manufacturer sites have their own comparisons. Skewed to their own benefit of course, so I went through them all. Heres kubota's just for fun.
http://kubota.com/assets/product/comps/RTV1100/RTV900_1100comps.pdf
In the end I went for a polaris ranger xp 900 3 seater gas version (4x4). (cost $11, 000)The polaris can tow 2,000 pounds, weighted only 1400 lbs so I wouldnt come crashing down on stones, had the highest clearance available, and I like the fact it had a CVT vs the HST. When I spoke with one of the mechanics he said something that made sense. The CVT was cheaper and sometimes easier to fix and you could change the belts yourself.
So far I pulled my Scag out of two mud holes when I was cutting, used the flatbed to haul eight 5 gallon buckets buckets of water, multiple times for some distant fruit trees I planted, used it to stow my chainsaw, gas and oils for cutting trees in the woods and moved a small couch with it. lol
Im still breaking it in so I'm taking it easy. Although I miss the maneuverability, and stone wall, log jumping capabilities of my old kawasaki 750, the comfort and increased work capacity of the side by side is something I can get used to. So far so good!
