Protective cover for mid pto for B2650?
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Snowblower is finally off, and I am wondering if there is supposed to be a rubber cap for the mid PTO to protect the splines the way there is on rear PTOs?
4,973
Morning there sunshine,, and no I dont believe there is a cover for it, but then it wouldnt be the fist time I have been wrong this morning :D
7,444
Might give the splines an overdose of WD40. It's a water dispersant and will keep rust off. Or wipe some grease from your grease gun on them.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
I was thinking more about protection from rocks and sticks..guess a cap might get knocked off a lot.
07wingnut
271
118
Clearwater, BC, CA
Made one for the BX23 from some pvc pipe. It's a friction fit over the pto and provides some mechanical protection but mainly keeps the crap from building up on the pto shaft. Don't have a pic right now but will post one later today.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,358
569
Richmond, Virginia
I may never use my Mid PTO, IDK. But every engine oil change, I wipe the PTO shaft down and slather it with water proof grease. I do the same with the rear PTO when I put on the BH.
It is easier to clean a little grease 'splatter' if the PTO is running free than to remove the rust from a shaft when you are trying to use it after a long period of inactivity.
I think (suspect) the cap on the rear PTO is a safety thing, to help prevent injury (shirtails???) from getting snagged on it when spinning. It certainly wpould work wonders are holding in dampness..... ;)
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Hi Sheepfarmer. Mine didnt come with one either, but when I asked my dealer about it he found a rubber cap at the dealership off of something that works perfect. I will try to find out what it was from.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Thank you!
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Thanks everyone, I am glad to hear that at least this is not another item that I have misplaced...and that something needs to be improvised. There are a few hazards in my pastures and just when I think I know where they are, some more show up.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Hey sheepfarmer. My dealer has another cap for the mid pto shaft for your B2650. I always keep fluid film on both shafts, and keep them covered when not in use. I will pick it up as I havent been out there and looked at all of the orange for a while, and send it out to you.
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Wow! Thank you so much! That is really nice of both of you.
NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Nov 28, 2015
424
Pennsyltucky
I was driving through a bumpy section of the woods with mine and came close to landing on a large stone. It could have damaged the shaft if I hit it. I was going to ask a skid plate maker if they could fab one for the mid pto area. I need some armor! I greased mine up at the end of the season to keep it nice.
