Turning Plow on B7800
bcallaha
B7800 w/Loader
Apr 1, 2010
21
Chandler, Indiana
I want a turning plow. I was thinking that I would get a 12" 1 bottom. I have the opportunity to get a 12" 2 bottom for $250. I don't have the rears loaded on my B7800, although I'm thinking of doing that. At 30hp, I have the hp, but do I have the weight and traction to pull a 2 bottom? My old 25ph Ford would, but it weighs twice what the B7800 does.
Thanks for your input.
Brad
jeepfreak1972
2011 L3800 HST
Oct 28, 2010
31
Ravenna, MI
My manual for my B3200, which is about the same tractor as yours from what I have been told, says it can pull a 12 inch 2 bottom plow.
Steve
Orange Tractors
L175 w/Woods L59, Allis Chalmers WD
Jul 19, 2009
323
Butler, MO
In my opinion you will definitely want the rear tires loaded. I have plowed with my AC WD with and without. With the tires loaded, you get enough more traction to make it seem like you have double the HP and torque available.
Robert
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Like its often said with a Kubota you'll loose traction long before you loose power. I say fill up the rear tires and give it a shot. Whats the worse that could happen, you till up dirt?
