L3650 Wet Clutch needed
Yeats5.0
L3650
Jun 12, 2017
Greenwood, in
L3650 tractor, has the "ever clutch" EC on the rear fender. Clutch is bad, Kubota says there are none available in the country. I currently have the clutch sent out to be rebuilt. They have had it for 4 weeks and I still don't know how much it will be. I know that some of the disks have to be replaced so they are talking with a machine shop to have them custom manufactured.
Any body got a good one laying around?
Any body got a core laying around?
Any body know what other Ever Clutch tractors will interchange with mine?
Thanks for the help!:confused:
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Did you try any of the Tractor Recycle yards? They are listed in the Sticky on top of the Service Repair and Maintenance forum. Think they are also in sticky on Implement forum
Rbell6
22
Mi livonia
Have you heard of a compay called Tribco based out of OH. I have used them in the past with good results and fair pricing.
11,110
35080-14302 check this part number may be what your looking for
I think it's an obsolete part #, Several sources have said, but you never know, be it highly unlikely, they might have made another run of parts for it. ;)
Rbell6
22
Mi livonia
Looking deeper into it, I believe your right. Messicks just hasnt updated there website. Id call Tribco I have used them before on older clutch's that I needed relined.
L2950 GST
L2950 GST
Nov 26, 2017
10
N.K. RI USA
I have a L2950 GST your clutch is similar it just has a separate side with reverse having it's own disks.I am sure you can by the clutch disks and snap rings. I had same problem trying to buy entire unit. I fortunately found one in the US. If you look at your model on Kubota.com parts breakdown and get the individual and kit part numbers
you can find out more from Kubota dealers.
11,110
Sadly no individual parts are available for the EC's, and even getting the whole clutch pack assembly is getting very iffy at best.
