My L3130 starts then dies within 2 seconds. I have read about and troubleshot the fuel stop solenoid and relay. The relay checks out per the shop manual, as does the solenoid (15 ohms on one coil, .6 ohms on the other). The solenoid makes a solid audible clunk when the key is turned on. After the engine dies and I turn off the key, I can hear the solenoid clunk again. Is it possible that solenoid activates but the plunger the blocks the fuel doesn't move?
There is fuel in the filter bowl.
When the output hose is removed from the fuel feed pump and we crank the engine, no fuel flows out. Does the fuel stop solenoid block output of this pump?
Any ideas?
-Jason
Any ideas?
-Jason
