BX2370 wheel spacers
Bxrider
BX2370 60"mmm FEL snow plow
May 25, 2017
Spencer WV
Hello all I'm new to your forum family.
I've been looking at it for a while but joined
today. I've been looking at wheel spacers for my BX for
A while. Found these on eBay just wanted to share
Put them on today fit is perfect
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Nice buy. Hope they work out for ya. I just put on some two inch Brotek spacers. Nice improvement all around for sure!
And welcome to OTT!
Manvito
Kubota B2601
Apr 27, 2016
106
New York
I don't mean to hijack you post but how did you find out those fit your tractor? I have a B2601 and I really like the price of those spacers. I'd love to hear what you think about the quality of those spacers as well.
BotaLoda
BX2370, Loader w/tooth bar, MMM, sub soiler, 5' rake, rear ballast box, forks.
Feb 28, 2017
134
Cosby, TN
For reasons I won't get into, I got a 54" deck. I see they have 1.25" spacers. Are they going to help or a waste of money. (although at that price I think it's a risk I'll take). My dealer also had the tires filled, I'm guessing while laying flat or maybe at a slight angle. They were TOO full. Not enough air in them for the tires to compress on bumps. With the valve stems at the top I let out the extra liquid and filled with air. I have a good amount of rear ballast. Would it get more stable if I let the liquid out to about half way/axle level?
Bxrider
May 25, 2017
Spencer WV
To make sure they would fit my BX I looked for spacers with their specs listed.
Bolt pattern and wheel center size were what I went with.
As far as quality fit was perfect, spacer material and hardware were the same
as those listed for a BX.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
302
northern lower Michigan
Absolutely amazing to find spacers for a Jeep that the bolt pattern matched
to fit your Kubota and a cheaper than dirt price to boot. If they do in fact fit
and work out as planned sharing the information and source is awesome and
what the forum is all about.
Kudos!
Al
Bjones
L2800
Apr 23, 2017
46
walhalla, s.c.
I too am looking to install spacers for the stability factor. Will the spacers case any structural damage or cause any damage in any way. I have a L2800 and use my tractor on hilly areas and the extra wide footprint would be helpful. Thought about 2". Who has the best price and quality spacers? Thanks guys
Bxrider
May 25, 2017
Spencer WV
Kudos!
Al
They have been on my BX2370 since the end of May.
They do make it a lot more stable.
Bxrider
May 25, 2017
Spencer WV
I tried to find those spacers that the OP listed, but I cann,t find them.
By any chance, can you post a link to those from e-bay ?
I don't have the link, search 5x4.5 wheel spacers then make sure they will work with the center hole of your wheel. Hole size should be listed in their specs. I know the ones listed for jeeps work, I think maybe the ones listed for Ford might.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
Can these spacers be used with the 54" mmm?
No, 1.5" max with 54" mmm.
My 2" push tires close enough I can't remove pin and spin bogey wheel 90° to make deck slide out effortlessly. Now Im dragging the two rear wheels. Oh well.
Orangeglow
2015 BX2370
Jun 19, 2014
332
151
Prescott, Ontario
Thanks for the info.
I found the 2 inch spacers on e-bay, but they are out of stock for a couple more weeks.
I ordered the 1.5 inch ones and will also get a set of 2 inch ones when they are back in stock.
howie70
BX2370
May 29, 2013
22
Shenandoah Valley, VA
I have scoured ebay looking for 1.5" spacers to fit my BX2370. My center hole is 3.125" or 79.375mm. I can't find anything close.
Any of you guys mind posting a link to what you found?
