rkidd
I had been looking for quite some time for some SSQA pallet forks for my B2650 to shuffle implements in and out of my shipping container. Just really didnt want to spent 5-7 hundred dollars on a pair. I finally found a pair of 48" pallet forks down the road for $100.00. Price was right. They werent quite SSQA but with a little fabbing and welding I knew I could make them that way. They did have somewhat of the top lip, but was too narrow. I had to widen about 1 1/2" on each side. Had to cut the side supports off about a foot down as it angled in and was in the way to extend the top lip. I then welded a new side support in vertical to the top lip so the SSQA from the tractor would fit in. The original bottom latches would not work at all, so had to cut them off. I then cut out some new ones and weld them on at the correct angle to fit properly. There is a hole where the bottom latches were which I will patch back in. All in all came out good, and they work great.
View attachment 29503 View attachment 29504 View attachment 29505 View attachment 29506 View attachment 29507
