Is mower deck RCK60B-22BX compatible with BX2370?
allibaster
Sheridan, WY
Is the RCK60B-22BX mower deck compatible with BX2370?
I can't find a compatibility matrix anywhere. I've called the local Kubota dealer, and he wasn't 100%, but said it should fit. His rationale was that the BX2200 is very similar to the BX2370.
I'm considering buying this deck and a BX2370 off craigslist separately, but I need to make sure it fits before taking the plunge.
Thanks in advance!
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
The dealers will have the correct attachment information, and I expect with most model/series changes there are generally some minor change in linkages, attach points or similar, which make them incompatible. So for direct fit, there may be some discrepancies, whether you can or need to adapt is another thing. Sometimes it may be a linkage length, other times a lot more. I had a very quick look at the 2 decks diagrams and there are attachment point and pivot arm/hanger differences.
allibaster
Sheridan, WY
Thanks for digging into it.
Like the points you have mentioned, there's a lot of variables. I'm kind of bummed out my local Kubota dealer couldn't give me a straight answer. Just "it should". I might have to call other dealerships. It would also be nice if Kubota had some comparability documentation.
11,298
Well considering that is the EXACT model that Kubota calls for use on the BX2200, I would say it will fit exactly...
Some of the dealers out there need some education! ;)
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Only problem is that he is asking if the RCK60B-22BX will fit the BX2370, not a BX2200
