Front rim broke! '77 L185DT
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
Hi Orange tractor folks,
I was doing some front end loader work today and cracked my front wheel, between each bolt hole. Looking at the broken parts, it looks like it was half broken (rust) and then today's work finally fatigued through the rest of it.
Does anyone have a 6-14 rim in usable condition I can buy from them?
Pics for attention
Sent from my VS986 using Tapatalk
redmaher
253
US
I might. I know it's 14 not sure on width. From a b21.
Sent from my LG-H901 using Tapatalk
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
I think I'm looking for 14x6. 7 might not change things too much. I'm looking at Farmland Tractor Supply in Tangent, OR as well but their inventory seems to be limited
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I may be accused of being a cheapskate, but I'd weld that back together and never think twice. Grind it clean and go for it.
One of my front wheels shows previously welded cracks and washers to close up the sloppy holes and it's been holding fine since I've owned it.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
I agree...weld it for now...but keep looking for a cheap spare. Nothing ruins a weekend of work like a 2 hour tire or rim repair run...
8,840
If you do choice to weld it, you need to either remove the valve stem or better yet remove the tire from the rim as if you leave it aired up it has the ability to expand and explode! :eek:
Yooper
3901 LA525
May 31, 2015
1,648
791
NE Wisconsin
I would add a backing plate that would fit inside the inner circle of the wheel. Even a quarter inch plate skip welded (don't weld all the way around) would go far to keeping the wheel from cracking again. Personally, I'd recommend replacing the wheel.
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
Thank you all for the suggestions! After a lot of phone calls to local shops, my wife stopped by Farmland Tractor Supply in Tangent, OR and they happened to have a 16x4 wheel with the exact centering hole diameter. It was for A John Deere so it had a larger 6 bolt lug pattern. They recommended we use the center part of the old wheel as a template and drill new lug holes in it.
We got the new holes drilled, did a little bit of fitting, and I used it for about 1.5 hours with no problems.
The best part? $125 for the wheel and a brand new tire, already mounted.
I may weld up the old one to have as a spare, though the tread would be facing backward if I used it on the left front.
8,840
Being that it's a DT (4wd), you really should change the other tire to match. ;)
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
What's really funny about that is that the tires were already pretty poorly matched, and the new tire and existing front tire seem to have very similar tread life remaining! :)
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Glad the former poorly matched tires on a DT had a rusty rim as a fuse to break instead of things inside the transmission etc.
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
Right? The break pattern does look a little bit more like a torsion break as opposed to a side-load break, until the end.
The mismatch (and good practice) is most of the reason I pop it out of 4WD as often as I do.
redmaher
253
US
It's very important to paint the rim kubota orange....being John Deere yellow might make the cost of replacement parts go up.
