M6950 help needed. Will only drive in A & B Range
CalicoJack
M6950
May 6, 2017
NE PA
As stated above Tractor will only run while in A or B range. Can use all 3 gear and reverse in those ranged but if you go to C or D tractor stalls out.
Any help on what I have to look at?
Thanks in advance!
6,891
#1 advice for issues like this is get the WSM (aka service manual) it most likely will have a troubleshooting section on the transmission to help you sort out the issue. ;)
