Hi
This is a 2012 RTV 1140
We were concerned that the electric gage was malfunction so I installed a cap tube gage at the thermostat housing.
We find the electric gage was working correctly and the engine coolant temperature is actually getting up to 235 to 240 under a long run on soft terrene.
We tried using a lower gear setting and that didn’t help.
My question is what is the maximum safe coolant temperature for this engine?
If these temperatures are too high then what shall I check to try and change this.
When we started trying to figure out what was going on we let the unit idle for an extended period of time the temperature didn’t exceed about 180 degrees. We then tried driving the unit around the repair facility compound and still didn’t get temperatures above 200 degrees. After 1 1/2 miles on an improved hard pan road the temperature was at 220 degrees. Another mile on a soft sand trail and we were at 235 to 240 degrees.
Any suggestions?
Phil P
Any suggestions?
Phil P
