I bought a QH for my L2501. After reading up on them, I decided to try out the harbor freight quick hitch.
First thing I try and hook up is my Landpride BB1260 box blade. QH compatible from the get-go. When I hook the lower larger upper link pin (per Landpride), and it's hanging firmly on that upper hook, it lacks bottoming out in the bottom hooks by over 5/8".
Vertical distance between hook bottoms on the HF QH is 15-1/2", with the top hook in the bottom set of holes. I can't find it right now, but did find a diagram online that showed the Landpride vertical distance pins to pin is expected to be 14-3/4".
I figure it will be a problem when I go to tilt side to side, it will have to make up that slop first.
Anyway, Thinking about getting the LP or SpeeCo quick hitch instead. Am I right in expecting either to fit better?
Thanks,
Thanks,
