Woods BSS72 Box Blade
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
144
SW Washington State.
Anybody have any experience with a BSS72?
I am looking for a box blade to fit up to the MX4800 I have on order. Dealer suggested this one and they have been 100% spot on so far. I have no experience with a box blade but looks to be a handy piece of gear. I have a LOT of leveling to do and a lot of limbs mixed up with dirt I am moving.
M
Missouribound
Jun 17, 2014
646
38
Missouri
If you have a lot of debris maybe look into a rake first. The box blade is a leveling and moving device but doesn't do well with landscape debris other than rock and dirt. The branches will get caught on the scarifiers and you will be getting off to clean them. You need to get the garbage out of the way first either with a rake or a pass with just the scarifiers and the blade way up.
Bulldog777
L3200, RTA1266, Modern 5' BB, Mustang 60 FM
Jan 25, 2017
215
You want the box to cover your wheel width for sure. Box blades are an awesome implement. You can drop the scarifiers down and break up compacted material and remove roots. There is a video that may help: https://youtu.be/LxuEDGSGOZA
Sent from my SPH-L720 using Tapatalk
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
I have a 15 year old Woods 72" heavy duty box blade. it weighs a little over 500 pounds IIRC. Great implement, very useful and indestructible. Your M should handle the bigger one just fine.
ADK4WD
42
King creek or CaptMike -- or anyone w/BoxBlade: I'm looking for either a 6' or 7' BB and so far have been disappointed in the quality of the Land Pride 2572 and Woods BS models - both seem "Light Duty" regardless of their "Heavy Duty" claims...they each weigh UNDER 600 lbs. I have some rocks on my property and will be pulling behind an MX5800 - don't want it to bend/twist and not hold up?? It seems the better BoxBlades in the 6-7 foot width weigh between 800-1100 lbs but cost over $1500+. I need to stay UNDER my budget of $1000.... I may buy "used" if I can find one locally in decent shape. Another "decent" one appears to be the Dirt Dog MBX72 - at 640lbs...still light/medium duty but only cost $1000-$1100.
Any thoughts of recommendations ?
captmikem
Mar 16, 2017
144
AKD,
I have had the BSM 84 for a couple of weeks. It seems stout to me. I have been using it to cut down a hill and move it into a valley. I have gotten into rocks now from fist sized to some a bit bigger than a basket ball. I drag the rippers through it and it digs up the rocks. So far I have hardly scratched the paint. It weighs 750 lbs and the end plates are 1/2 inch thick.
I also used it on my friends gravel drive. taking off the crown and filling some ruts. noisy as hell but did the job well.
I am happy with it and I like the weight as a counter balance for the FEL.
Hope this helps,
M
ADK4WD
42
CaptMike you are correct on the Woods BS"M" - much heavier than the BSS that was mentioned to start this thread and it was the BSS that I was referring to when I expressed concerns about it's LIGHT duty quality. The BSS is only 5550lbs and therefore several 100lbs lighter than the BSM models. I would be very happy with a BSM - just not sure I can spend the extra $$ for it. Woods certainly makes some quality heavy duty Box Blades in addition to their "hobby-home-owner" line. I am looking for something 6'-7' and 650lbs to 800 lbs IF -- "if" I can afford it....still looking hard for a decent USED one.
FTG-05
Jul 21, 2013
257
101
TN
Thanks for the information,
I decided to go with the BSM84, bit heavier and wider.
M
the biggest mistake with my L4330 that I made was following the "conventional" wisdom and the owner's manual for implement size. Hence, I got a 6' bushhog, 6' BB, 6' rake and a 6' disc. My rear tire outside to outside is +76 inches.
My L4330 is a 40 hp tractor, yours is 49 hp (per TD). For that size tractor, I would never buy anything less than 7'. For my rear grader blade, I'm gong 8'.
And FWIW: I added about 760 lbs to my already HD BB weight of 675 lbs. Now - it works good!
Oct 8, 2014
623
oregon
Move the rear tires.
