Hi, im new to this forum. Im actually asking this for someone else. The tractor is an M9000 with between 2000-3000hrs, the tractor is shutting off on its own. The iol pressure light starts flickering on and when the light is fully on the tractor shuts off. Started doing this at 600-800rpm, now several weeks later its shutting off around 1400rpm. Usually does it worse when the engine is fully warm. Oil filter and oil are fairly fresh. Anyone else had this happen? Whats causing it to happen? Whats the fix? Thanks
