M matt1985 New member Equipment l2350 Apr 6, 2017 3 0 0 west branch michigan Apr 6, 2017 #1 i have a 1998 L2350 and wouldlike to add water temp gauge to it does anybody now howto do this
1 100 td Active member Equipment B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat Aug 29, 2015 1,776 9 38 ɹǝpunuʍop Apr 6, 2017 #2 Depending on your housing, there may be room to drill and tap a thread into the thermostat housing where the flat area near the little return pipe as pictured http://i.ebayimg.com/images/g/ipUAAOSw5VFWKdPH/s-l1600.jpg They also make temp gauge kits with probes that slip under the hose, but they are not my preferred option. There are also kits that bolt a sensor under the thermostat housing bolt, search ebay for them. Ha, look what you get for $6! www.ebay.com/itm/262715408072 www.ebay.com/itm/371514999990 www.ebay.com/itm/282418153320 www.ebay.com/itm/142339003155 Last edited: Apr 6, 2017
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,024 6,994 113 Sandpoint, ID Apr 6, 2017 #3 Just remove the plug in the right rear of the engine and install a temp probe. Attachments L2350 Water Port.JPG 49.9 KB Views: 419
1 100 td Active member Equipment B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat Aug 29, 2015 1,776 9 38 ɹǝpunuʍop Apr 6, 2017 #4 NIW, What thread does he need to look for?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,024 6,994 113 Sandpoint, ID Apr 7, 2017 #5 100 td said: NIW, What thread does he need to look for? Click to expand... It's most likely 1/8 BSPT, very common in temp sending units.
M matt1985 New member Equipment l2350 Apr 6, 2017 3 0 0 west branch michigan Apr 9, 2017 #6 thank you sir
M matt1985 New member Equipment l2350 Apr 6, 2017 3 0 0 west branch michigan Apr 9, 2017 #7 North Idaho Wolfman said: Just remove the plug in the right rear of the engine and install a temp probe. Click to expand... thank you sir
