Took off the front hub assembly to replace leaking pivot seal. Cannot get the seal off shaft. Any suggestions. Have removed all snap rings etc..last two things take off are bearing and seal. Tried hammering out by putting an oversized socket around bearing and whacking it but no go. Got it about 1/4 inc off shaft. Have attached pics.
Thanks!
Chris
Edit-the guy at the Kubota shop in town told me that the assembly would "slip off" once I removed the internal/external snap rings and gears..then easy fix to replace replace the seal....not. I'm thinking I need a bearing puller since this has been on for 12+ years...anyone else had a hard removing the seal from the shaft? It definitely didn't slip off!
A couple more pics. I'm thinking I have to rent a puller. Anyone run into this?
Thanks!
Chris
