Now that i have a box scraper someting new has reared its ugly head. The adjustable side link on my three point is on its last leg. I have a couple small hydraulic cylinders. Picture one on each 3 point link and a valve connecting the 2. As one extends the other retracts. Open valve and implement levels itself while parked on the ground. Need to angle,set one corner on a block and open valve while lowering 3 point. Close valve and away you go. The cylinders im thinking of using are double acting so a second line joining the two open ports should take care of leakdown. I really dislike cranking that adjuster anyway.
Thoughts?
Thoughts?
