Simple & Inexpensive FEL Bucket Level Indicator
BatesBunch
Kubota B2320HSD
Feb 25, 2017
Picayune, MS
I have had my B2320HSD for a little under a year and this is essentially the 3rd customization (not including adding the LA304 FEL). This is my 3rd tractor, but my 1st Kubota and I am very much enjoying it (I previously had two grey market Yanmars which were both good tractors that were sold to help fund my Kubota).
Now, on to the subject of this post: Another option for a Front End Loader (FEL) Bucket Level Indicator...
I saw multiple posts around the internet for DIY FEL Bucket Level Indicators while looking for ideas for one to install on my Kubota B2320 w/LA304 FEL. I set off to town to get the 'parts' after I had decided on a variation of several different 'designs'. My initial design was going to be the typical steel rod, but that changed while I was shopping/configuring and I came up with an indicator that consists of very inexpensive parts and was a fairly quick & simple install. I decided to go with a fiberglass rod as it would be more forgiving than a steel rod, if bumped (and I liked that the orange rod was a close match to the Kubota Orange). Stainless steel hardware was used to ensure a clean and maintenance free installation.
- An eye bolt was used for the rod 'guide' as the LA304 FEL already had a couple of factory holes near the bucket cylinder pins on the loader arms. A 3" eye bolt was chosen to ensure that there was enough clearance between the rod and the bucket cylinder hoses.
- Rather than drill & tap the cylinder pin at the bucket, a 1/4-20 nut was tack-welded (on 3 of 6 nut 'flats') to the center of the cylinder pin to create a mounting point for the rod 'pin'.
- A 1/4-20 x 1 1/2" bolt was used as the rod pin. A nut was 'bottomed' at the end of the threads, limiting the travel of the rod end to the bolt shoulder between the bolt head and nut. A second nut was used as a lock/jam nut against the welded nut to lock the pin in place.
- A piece of 3/8 copper tubing was used for the rod end as the fiberglass rod slipped snugly inside. 3/4" of the tubing was flattened to form a 'tab' and drilled with a 1/4" hole for the rod pin. The original plan was to use a 3/8" x 3/4" long steel spacer and tack-weld a 1/4 flat washer to one end to use as the rod sleeve/end. Another variation would be to make or modify a clevis end to slide onto the rod. Both are still options if the copper rod end doesn稚 hold up.
- Rod was trimmed to 2" above the eye bolt guide with the bucket in the fully-dumped position and the protective cap reinstalled.
- Electrical tape was used to mark the 'bucket level' location on the rod at the eye bolt guide.
Parts list (prices/total before sales tax):
48" Reflective Fiberglass Marker Rod; $1.99 @ Home Depot (HD); found with other driveway markers/mailboxes
1/4-20 x 1 1/2" Stainless Steel (SS) Bolt (Rod 'Pin'; $0.42 @ HD
1/4-20 SS Nuts, 3 ea; $0.26 ea @ HD
1/4-20 Std Nut (to weld onto the bucket cylinder pin & become the mount for the level indicator rod pin); no cost (had on hand)
1/4-20 x 3" SS Eye Bolt (Rod Guide) (comes with one SS nut); $1.49 @ Tractor Supply Co. (TSC)
1/4 SS Flat Washers, pack (only needed 2 ea for the eye bolt); $0.99 @ TSC
3/8" Copper Tubing, 3" length (to fabricate rod end); no cost (had on hand)
Total cost: $5.67
I appreciate the ideas that I have gleaned from in the past and hope that this idea may benefit others.
L3010HST
L3010HST w/LA481 loader; Land Pride RB2672 Blade and RF2060 Rotary
Apr 29, 2013
55
PNW
Very clean install. Much nicer looking than how I did mine.
jkcolo22
BX25D
Jan 5, 2017
291
Castle Rock, Colorado
Nice work. But anyone else concerned about expansion of that cylinder pin during welding? Or no concern with a quick tack weld?
BatesBunch
Kubota B2320HSD
Feb 25, 2017
Picayune, MS
Thanks for the comments. Hopefully this gives another design idea for folks with smaller tractors.
I wanted to clarify that the bucket pin was removed to tack-weld the nut into place. Three tacks with minimal heat and the pin was allowed to cool before reinstalling.
jkcolo22
BX25D
Jan 5, 2017
291
Thanks for the clarification. Makes sense that way and no risk of a stuck cylinder. I guess I was just thinking of doing it the lazy way. I'm going to try something like your idea. I bought the level indicator kit from amerisolutions but I couldn't bring myself to drill a hole into my new loader arms. Will try to fab something up using the welder instead of drilling. Wish I had seen your simple solution first, but I guess now that I have the amerisolutions kit, I might as well use what I have. Sorry to hijack. Will post a new thread if I'm successful.
coachgeo
Nov 16, 2012
2,460
37
Southern OH
.. Will try to fab something up using the welder instead of drilling. Wish I had seen your simple solution first, but I guess now that I have the amerisolutions kit, I might as well use what I have. Sorry to hijack. Will post a new thread if I'm successful. ...
There is several threads on this topic. Lots of great ideas to review before fabricating your own.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Ok... I have to ask. What does it mean to "bottom" a nut? And what is the process?
I believe he just means that the nut was ran down the the end of the threads. Look at the last picture of the first post, there's a nut that locks the bolt into the welded nut, then the nut that's bottomed to the end of the threads so that the rod can only travel on the unthreaded portion of the bolt between that nut and the bolt head. That may work just fine, but seems like that nut would eventually vibrate loose, I'd either use a second nut to lock it in place or use a nylon lock nut there.
BatesBunch
Kubota B2320HSD
Feb 25, 2017
Picayune, MS
Good explanation by scdeerslayer. A nylon lock nut or an additional nut to act as a 'jam nut' could be used, but there was enough tension when the nut was tightened against the bolt shoulder at the end of the threads to lock the nut in place. As suggested, a lock or jam nut would be needed if this wasn't the case.
