Maybe not a good idea
danrn2500
B2920, belly mower, loader, PHD, 3 point box
Jan 16, 2017
Colorado Springs, CO.
Had a section of old fence that I decided to remove. Some poles were wood, the others were metal. The wood I just pushed over. The metal poles had these notches in them so I decided I would try to hook the bucket on them and pull them out. Did one and it worked pretty good. Tried the next one, and the rear of the tractor raised up pretty high.:eek: Needless to say that got my attention, and I went back to pushing on the poles.
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
10
Lovells, Mi
Put some counterweight on the 3 point. You could probably use you box blade if nothing else. Put some planks on the top of the box blade and add some extra weight cement blocks, sand bags, whatever... Not sure what your tractor is rated for on the 3 point probably 800# or more.
Bulldog777
L3200, RTA1266, Modern 5' BB, Mustang 60 FM
Jan 25, 2017
215
When I was a kid we did not have a FEL for quite a while. We use the 3pt and a chain to pull posts. Worked like a charm, of course I was operating the chain. :rolleyes:
bcp
BX2360
Apr 20, 2011
645
78
SW WA
Try each post carefully. If it comes out--OK. If it doesn't, get your t-post driver and drive it in a couple inches deeper. Then it will most likely pull easily.
Bruce
Tooljunkie
May 13, 2014
4,150
Couple ways,chain and lift a little and wait. Drive ahead a touch and they should go. Lift ,wait repeat.
No go? Pour water around pipe and inside pipe. Try again later.
Eray
L2501 HST
Feb 24, 2015
84
Lenoir City, Tennessee
Bruce
Good idea. I have pulled dozens of T Posts. Don't know why it never occurred to me to drive them in further to break the ground seal. I guess you are never too old to learn. Thanks for the idea.
5,586
If you have a draw bar for your 3 point arms, wrap a chain around the post at the ground level. Back up to the post and wrap the chain around your 3pt drawbar. Up comes the post!
A "T" post is only in the ground about 17" typically. If you don't have a drawbar as described above, just sling a chain around the post at ground level, pull up to the post and attach the chain to a hook on your loader bucket. Pull gently, if the post does not come up, go forward a few inches, then back. Try pulling up again.
On a "T" post you don't have to hook the chain at the post. Just wrap the post 4 or 5 times and lay the chain over it's self. It will snag on the bars and lock in place.
DocHolladay
MX5200, FEL
Oct 19, 2015
88
Murfreesboro, TN
We wrap a chain around the bottom of the t post and then lay the chain over an old tire that will hold air, that is right up against the post. Hook the chain to your draw bar and pull. The tire will allow the chain to pull straight up on the post and should give you leverage to pull it out. The air in the tire gives a little cushion so that the chain hopefully doesn't break. We pulled an old cb antenna tower out of the ground like this and it was in the ground at least 6', probably more.
2,556
What Doc said.
I've used an old rim (no tire) to do the same thing.
6,596
That was my job as well when I was a kid :rolleyes:
