made a simple level indicator for B2601
2,679
very nice indeed !
Take a closer picture of the pivot point on the lower cylinder - like to see how you attached to the ram.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Thats a good idea. Very nicely done. No excess linkage.
mdhughes
L3901DT
Dec 10, 2014
1,291
888
Ste Geneveive county, MO
Is there a reason that you put it on the outside of the lift arm and not on the inside? I have seen something like that somewhere else using PVC pipe, but yours seems to be a cleaner look. Very nice job, I'll have to look at doing something like that. A lot better than $75 for the one that Kubota sells. Thanks for sharing!
Rosher18
L185DT (1977)
Aug 2, 2016
Salem, Oregon
I may have to do that on my L185. I spend time in the manure pile and I don't like to accidentally dig down when turning it, because it makes it hard to get in and out with a full cart.
Plus I won't have to lean way outside the tractor to figure out if the bucket is level
Sent from my VS986 using Tapatalk
Husker
9
Western TN
inside has all the hoses.. I have the 3rd function hoses there, too.
had to be on the outside
fendley
L3901, LA525, BH77, SVL65-2
Dec 31, 2016
120
St Marys, GA, USA
Haven't used a FEL with a level indicators, so excuse my ignorance:
Does the indicator indicate level only when the bucket is close to the bottom position?
Husker
9
Western TN
I made a couple marks on the rod.. one when down on the ground.. and another one when higher off the ground.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Just now logging in where I can see photobucket. Very similar to mine except I did it on the other side inside the arm. I didn't think to attach it to the cylinder rod though, that certainly would have been easier, but looking at my pictures now I don't have enough room to do that.
