B2601 owners
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
344
128
St. Louis, mo.
Wondering how the b2601 handles on hillsides nothing real steep maybe 20 degrees. Does it feel top heavy with a balanced load. Trying to figure if there would be a big difference from my bx2660 .. thanks
2,551
You have spacers on your BX?
B is going to have a higher center of gravity - it simply rides higher and has more ground clearance. SO given everything being equal, yes - you will feel a top heaviness.
HOWEVER - if spaced a bit on the rear, IF loaded tires and IF ballasted on the rear with it lowered - you should not be too bad off the BX.
NOW this 20 degrees ....you going up it or sideways???? UP it you'll be fine, sideways.....not so much!
