J joebutler New member Feb 9, 2017 13 0 0 Hulbert Oklahoma Feb 9, 2017 #1 WantedUpper right lift arm b6100
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,745 2,551 113 Bedford - VA Feb 9, 2017 #2 joebutler said: WantedUpper right lift arm b6100 Click to expand... Try these places: http://wkytpstore.com/ http://www.crosscreektractor.com/def...ctor-parts.htm https://www.tractorpartsasap.com/default.asp
J joebutler New member Feb 9, 2017 13 0 0 Hulbert Oklahoma Feb 9, 2017 #3 85Hokie said: Try these places: http://wkytpstore.com/ http://www.crosscreektractor.com/def...ctor-parts.htm https://www.tractorpartsasap.com/default.asp Click to expand... Thank you, I have tried all three without any luck
007kubotaguy Well-known member Lifetime Member Equipment B7100DT L245DT JD 2355 Dec 23, 2012 642 255 63 Herald Calif. Feb 9, 2017 #4 Hello Are you looking for the arm that ataches to the rock shaft (splined cross shaft). If that is what you are looking for , I have one. Thanks Lance
J joebutler New member Feb 9, 2017 13 0 0 Hulbert Oklahoma Feb 10, 2017 #5 007kubotaguy said: Hello Are you looking for the arm that ataches to the rock shaft (splined cross shaft). If that is what you are looking for , I have one. Thanks Lance Click to expand... Yes sir 007kubota guy, that's exactly what I'm looking for. Hope I'm not breaking a rule but van you text or call nine1eight two0seven six09nine? If you call please leave a message and I will call you back asap
