1997 B7300
While the HST continued to drain I started on the crankcase oil change.
First I noticed the pan plug was leaking; an occasional drip. On removing the plug, it had to be wrenched out for several threads then, it easily came out by hand. I had expected it to spin out easily after initially wrenching it loose but it did not.
I've replaced the filter and I'm ready to replace the plug (with a new copper gasket). I can screw the drain plug in 7-8 turns but then it gets tight, some 4 threads before the base of the plug contacts the pan.
It feels as if I am screwing the plug into a nylon lock nut. If feels just like that, it goes in easy until I hit the "nylon" at the end of the nut and then it stiffens up. I don't imagine there is nylon at the end of the threads in the pan but that's what if feels like.
I tried taking it up a 1/4 turn and backing it off, then a bit farther and backing it off again, as if I was using a tap to cut new threads, (or repair damaged threads). But I stopped because it doesn't seem to be loosening up. I also stuck a rod gently up into the hole to see if the oil pick up or screen might be sitting over the hole and I was bumping into that with the drain plug but no, there is nothing for at least an inch over the hole.
I have a set of taps and dies but they are American fine, not metric. The bolt checks to 20 count NF 1/2 inch perfectly but the 20 count NF tap won't start in the hole. Odd.
I'm now wondering if the drain plug was originally metric and someone jammed an SAE 1/2 in plug into the hole.
Any thoughts or recommendations? Can anyone say if the original plug is SAE or metric? Is there by any twilight-zone chance a nylon lock at the top of the drain hole? (LOL)
Thanks for any help,
Mystified in central Ohio, Roll
I really don't want to pull the pan but .....
