I'm not trying to be smart or anything here, and I don't want to overstate the obvious. But this is the same tractor that half a dozen members tried repeatedly to explain how to set the valve lash properly on and there's no way for us to know if that was really done properly (if they aren't right, it aint gonna start).
As hard as he was trying it was really obvious that this sort of thing maybe wasn't something he understood real well. The current discussions about the glow plugs, starter and injector pump priming follow along that same line and apparent mechanical skill level.
I'm going to go back to the same advice I gave during the valve lash discussion. Find someone who understands diesel engines and at least have them look over your shoulder and explain these things to you as you go along. That way you can learn how to do it the right way. As it is, between the valves, glow plugs, injectors, starter and injector pump there are too many things that could be wrong for folks here to ever hope to help diagnose it in a reasonable fashion.
I'm curious...
Did it run before you took it apart?
If so then you:
1. Probably need to have someone help you confirm the valve lash settings.
2. Make sure everything is assembled correctly.
3. Make sure the pump is primed correctly.
4. Make sure the lines to the injectors are bled.
5. Check the glow plug system (although if you're working in a heated garage it should at least try to start or at least smoke some probably even
without the glow plugs).
Starter? it doesn't have to crank all that fast to start or at least try.
Besides that...
Was the head disassembled while off (valves taken out)? If it was then you needed to have the valves and seats resurfaced before reassembly. If you did take them out and didn't have them resurfaced then they're not going to seal and it's not going to start.
Was it a head gasket issue that prompted the initial disassembly?
If so did you have the head surface checked for cracks, straightness and flatness while off?
If not then the head gasket may not seal properly and it may not start.
Hopefully, you didn't bend any valves when trying to figure out how they should be set.
See, we're chasing the wind here there are soooo many possible issues that this is almost impossible.
You need someone there to walk you through it all.
That's not a knock, I'm sure you CAN learn how to do it. But some things some people need instruction and hands on help with to learn right. 4 cycle diesel engine operation, assembly and tuning may be those things for you.
