I was told by one source to try this to get it started but someone else said it can cause the air filter to suck it in changing the molecular structure of the oil causing other problems. Which is true?
why are you spraying silicone spray into the intake manifold? Are you talking about ether? ether is really bad on the diesel - it explodes early under combustion, and causes strain on the entire system.I was told by one source to try this to get it started but someone else said it can cause the air filter to suck it in changing the molecular structure of the oil causing other problems. Which is true?
It sounds as if you are attempting to use silicone spray inplace of ether as a 'starting assist'. It is considered very bad to use ANYTHING sprayed into the intake to assist with starting Kubota engines. SEVERE ENGINE DAMAGE can result. (Like chunks blown out of the engine block)I was told to spray it onto the air filter or remove the air filter to spray it a few short bursts. He said it doesn't dry the cylinders like ether does.
Here's the link to the product:
http://www.smslabs.com/product/silicon-spray/?gclid=CPD2nOuIz9ECFY-Kswodam8NGw
next part in this equation....I tested all 3 glow plugs and set the voltmeter to ohms. All three glow plugs measured .6. I tested the multimeter resistance at .3ohm. In the manual it says the glow plug resistance is .9 ohm. the battery shows 12v.
But is the 12v getting from the battery to the glow plugs? Did you try the test I suggested in your other thread yet?I tested all 3 glow plugs and set the voltmeter to ohms. All three glow plugs measured .6. I tested the multimeter resistance at .3ohm. In the manual it says the glow plug resistance is .9 ohm. the battery shows 12v.
If you had the power connection removed and the three glow plugs were connected together during the test (so all 3 were tested at the same time) your numbers sound OK. Three plugs with a resistance of 0.9 each, connected in parallel would be an equivalent resistance of 0.3 ohms. Add the meter's lead resistance of 0.3 and the reading of 0.6 sounds good.I tested all 3 glow plugs and set the voltmeter to ohms. All three glow plugs measured .6. I tested the multimeter resistance at .3ohm. In the manual it says the glow plug resistance is .9 ohm. the battery shows 12v.
I don't think 1.3 is horrible, but not good. Seems from previous threads say they should be <1.0, or close to 0. You'd have to research that further, as I'm not sure off the top of my head.I took the glow plugs out and they all rean 1.3 ohms. Not sure if that's good or bad. Also i thought that if there is a compression issue the engine would crank very fast. The engine cranks slightly slower than normal.
No, not necessarily.Also i thought that if there is a compression issue the engine would crank very fast. The engine cranks slightly slower than normal.
My thought with fast starter cranking has been associated more with timing chain/belt than bad cylinder compression. Since valves aren't moving, makes no compression, and just spins.i thought that if there is a compression issue the engine would crank very fast. The engine cranks slightly slower than normal.
And my wife tells me I'm not very smart...she doesn't use those words.......well, a lot of other things, too...35 years.....perfectly said - in order ....step by step!
Finally! I've asked about that in both threads now.It makes me think that power isn't getting to the glow plugs. Any thoughts?
