Carry-All bent frame at pins
kckndrgn
BX2370 w/ 60" MMM and FEL, Box Blade, Bush Hog, Carry All & Tiller
Mar 17, 2016
150
Somerville, TN
Afternoon all,
I was able to pick up this carry-all at a nice discount due to then damage to it. Figured one way or another I can get it to work.
Looks like someone either overloaded it or somehow pulled the pins so they bent the frame. Looking at the carry-all from the tractor side the left side is not to bad, but the right side has a significant bend to it.
You can see how the frame where the pins are located has been bent. I'm going to use this, hopefully, on my BX so I don't think I can use the top holes that are already on the CA.
What are my options? Heat and use a BFH to pound the frame back to a straighter position. Or, go 1" lower/higher and drill a new hole to mount the pins?
Thanks in advance for any help or other options.
Yooper
3901 LA525
May 31, 2015
1,564
665
NE Wisconsin
Heat and a BFH will straighten out the angle. Then reinforce it with some 1/4 x 2 flat stock like in the image and it will be better than new.
L4740
222
3rd Rock From The Sun
I may be inclined just to use it the way it is. Your BX will not bend it any further. The ball sockets at the end of your lift arms will accommodate that slight bend. Now if you want to make it pretty again, then follow the above instructions.
2,718
Yup, what they said, except I'd use a BF Pipe.
7,240
Pull the pins and put a pipe wrench with a cheater pipe on it, on the bend of the angle iron and it will bend right back. ;)
5,923
Looks like it was on a fairly heavy tractor and the front bottom got caught on something and the tractor kept on moving!
Since you're using it on a small tractor whatever you do to it only has to satisfy you.:D It'll work as is or modified.
nzzshl
1982 Yanmar GT14(YM146), 2015 BX25, BX5450 snowblower
Jan 12, 2015
85
Fenton, Mi
Judging by the downward angle of the pins, it would appear that the damage was not induced by something too heavy bearing down on the yellow horizontal load arms but rather an extreme vertical load pushing up from the bottom (or ground side of the arms). It was like someone grounded the base somehow, pushing up on the entire unit without the 3 points lift arms able to react when located on the lift pins. Having an a very basic understanding of the directional loading to cause the damage will go a long way in preventing a repeat after the existing damage is corrected. Maybe I am all wet in my presumption.
kckndrgn
Mar 17, 2016
150
Somerville, TN
I don't see the pins bent in a downward angle, but a forward angle.
Correct, pins were pulled forward towards the tractor. So it was like the unit was stuck on something and they kept pulling. I don't know.
Thanks for the input. I got some of the bend out of the right side, about 1/2 and i think I will leave it at that. I removed the damaged paint and primed it last night. I may just sand the whole thing an repaint it since there are a few spots where the paint has chipped away and it's rusting. Or I may not, LOL
