W wssmith524 New member Jan 8, 2017 3 0 0 Sterling Jan 8, 2017 #1 Anyone know if these are compatible or close enough to make it happen? Sent from my iPhone using Tapatalk Last edited: Jan 8, 2017
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,507 7,312 113 Sandpoint, ID Jan 8, 2017 #2 I think you have your numbers wrong, B2750 is a light dozer blade. Did you mean a BX2750C or BX2750D, as those are the two models that fit your tractor.
W wssmith524 New member Jan 8, 2017 3 0 0 Sterling Jan 9, 2017 #3 North Idaho Wolfman said: I think you have your numbers wrong, B2750 is a light dozer blade. Did you mean a BX2750C or BX2750D, as those are the two models that fit your tractor. Click to expand... I did get my numbers wrong. I meant to type B2650 snowblower. Found it used. Appears to be an older model not made anymore. Thanks. Sent from my iPhone using Tapatalk
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,507 7,312 113 Sandpoint, ID Jan 9, 2017 #4 Yea sadly the B2650 was meant for a much older tractor, and the chances of it working on your B2620 is highly unlikely.
W wssmith524 New member Jan 8, 2017 3 0 0 Sterling Jan 9, 2017 #5 Copy that. Kind of figured the same. Thanks Sent from my iPhone using Tapatalk
D Dj417 New member Equipment Kubota b5100e. Woods rm48 finish mower rm42 brush hog, kubota b36 tiller, Nov 6, 2017 7 0 0 Joplin Nov 6, 2017 #6 Where did you find that blower for sale?
