So my cousin who lives in Wisconsin just bought a BX2370-1. The manual says you don't need the block heater unless the temp is below 5F (-15C). Heck. The dealer there didn't even really seem anxious to install one! I advised my cousin to get it anyway.
So reading the manual further it talks about no load warm up after starting. The manual says set the RPM at 50% of rated speed and let it warm up 5 minutes (minimum!) above 32F, 5-10 minutes between 14F-32F, and 10-15 minutes when the temps are between -4F-14F!
Now there is 3.3 qts of oil, 2.8 qts coolant and 3.1 GALLONS of hydraulic fluid in this little BX tractor. So it seems to me to reduce this time AND to be kind to the tractor it would be nice to preheat this 3 gallons of oil. SO my first question (since I live in California and don't have access to the BX in question) is there a descent flat spot (3" X 3") on the bottom of the HST where one could install a "film heater" such as the Wolverine heaters (https://www.wolverineheater.com/Easy-Heater-Sizing-s/1827.htm).
According to their chart a 125 watt heater is good for 1-7 gallons of hydraulic fluid. Of course they don't say what temp this will get the hydraulic fluid to at a given cold ambient temperature and in what time. I think 250 watt would be better.
Anyone have any experience with this type of heater? Anyone have any wild guesses as to the effectiveness of one of these heaters in this application?
Thanks again.
Thanks again.
