Hey All
Quick question, I am replacing trans oil, I have the WSM so following that is pretty straight forward ( pull plugs, clean strainer, put plugs back in and fill with UDT, the only thing is the WSM doesn't reference the FEL.
If I just follow the WSM the oil in the 6 rams and all the lines on the FEL won't be replaced, is this common to not replace the oil in the rams or do I need to drain the Rams and lines then bleed afterward?
Sorry if been asked a million times previously but I had a bit of a search and couldn't find anything explaining what needs doing.
