My b8200's mid PTO has a hole on the inner spline to put a bolt or something though to attach a driveshaft. My mower universal joint has a corresponding hole. However my snowblower shaft has ball bearings on the inner spline with a slip ring that holds them in place once the shaft is in place. The problem is the blower shaft's inner spline mates to the PTO shaft's outer spline, which doesn't have a hole, since it's on the inner spline.
I don't want to leave the shaft on there with nothing holding it on other than friction, but at the same time I am not thrilled about grinding a divit on the PTO shaft for the ball bearings to grab on to. The previous owner used the blower, but I don't see how he did it without relying on friction to keep the shaft on.
Any suggestions on what to do?
