Is this supposed to move? FEL
Bcamos
L3901
Nov 1, 2016
125
Tractor has 40 hours on it. I've kept everything greased and today I started noticing a clicking noise coming from the FEL. I measured the mounts and they aren't spread apart. They're the same width at the welds as they are at the pin points.
https://vimeo.com/195868967
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,376
379
That's normal. Keep it greased and keep on working. No worries.
Bcamos
L3901
Nov 1, 2016
125
Perfect! Thanks guys. I hadn't noticed any movement before, so I was surprised to see it now. Especially after a fresh greasing a few days ago.
5,207
1,893
I know a guy (an engineer of all things) who put shims in there to "quiet" it down. I suppose it can be done but I don't see it to be a problem, unless you're an engineer and everything has to be "just right".
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
Is there a reason for so much play? I ask because when I built my FEL, I provided 0.010" clearance on each side of all pivots -- just enough for the grease to squeeze out, really. Was that a mistake?
Tooljunkie
May 13, 2014
4,150
Nope. No mistake. Think of mass production, dialing in .010 for a one off is nice, but achieving repeated gaps,.250 is easier to achieve. .250 is a guess.
2,549
Normal amount of play, but that doesn't mean it has to remain. I grabbed a selection of the correct size washers in various thicknesses, and shimmed most of the play out of mine. My old B219 FEL was so sloppy & loose that you could actually get a load to noticeably shift from one side to the other; not anymore.
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
Thanks for the reassurance. I certainly haven't had any problems with mine as built.
Other industries regularly get much tighter tolerances in production. Can you imagine if, for example, the A-arms on your car had that much free play? :eek:
I wonder if it was originally designed with larger diameter pistons in mind, say, before the project reached the accountants?
I think I would be another one reaching for the bag of washers.
Tooljunkie
May 13, 2014
4,150
Very bad feeling when a-arms start floating around. Had one that bushings became loose. Big prybar found them. Would change direction under heavy braking. Not nice.
I too would be shimming. Just make sure theres no binding through full stroke loaded and empty
5,207
1,893
It allows the loader boom to flex a little while being used; without binding the cylinders. It also allows for manufacturing tolerance. Some rubber shims would still allow some flexibility but would likely quiet it's operation down.
Yooper
3901 LA525
May 31, 2015
1,529
529
NE Wisconsin
I agree with Lugbolt, that space allows for when the side arms flex due to an uneven load. I was thinking a wavy spring washer, but rubber would be better.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,376
379
I must use thicker grease, because mine don't make any noise during operation.
I would not shim them with solid washers.
