jbjlock26
BX25D, Filled Rears, 54" MMM, R2 Mfg. 3" Edge Tamers w/12" Edge Extenders
I have a new BX25D with 4.5 hours on it. It is currently stored outside, like the new ones at the dealer. Yesterday I noticed an odd intermittent flash of the four-ways with the key out of the ignition. It continued for several hours. I used compressed air to blow out the light switch and did extract a bit of moisture.
While the intermittent flash has apparently stopped, I noticed that the turn signals operate as the manual indicates they should if the fourways are on. In other words, a right turn means the left stays on and the right flashes. Left turn means right stays on and left flashes.
Did I miss this before, or is this a malfunction? I went as far as unplugging the switch and spraying it with WD-40, then blowing it out again.
John in PA
John in PA
