CountryBumkin
BX2370 w/LA243, Bucket, Grapple, QA Pallet Forks, 60" MMM, rear blade & rake
The rear tires on my BX2370 are filled with water from Dealer (I'm in FL so no chance of freezing).
When I am checking the tire's air pressure, with valve stem at 12 o'clock, I am getting water out of the valve stem as I check the air pressure.
Is this normal? I assume that since there is air in the tire, the air wants to push out everything in the tire (the water).
So do I just add air and ignore the wet mess spraying out while adding air and checking the pressure - or am I doing it wrong?
