WTB Front Wheels and R4 Tires
wdlanning
L3750, L4310, B20, Genie Boom
Nov 7, 2016
224
11
philadelphia pa
Need replacement R4 tires and wheels for front of Kubota L3750. Original was 9.5-16. The wheels are 6 hole, 6 inch spacing. Would like slightly larger diameter wheel with the correct spacing.
9,393
Is it a 4wd?
If it is, it's not just as simple as changing tires and wheels!
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
It is 4-wheel drive and I understand the "leading and Lagging" aspect.
So then understanding it and apply that knowledge means you probably now
know that if you change the fronts on your 4WD to a larger diameter you're
also going to put larger tires on the rear to keep the ratio the same too.
Al
