ozzie, I'd look at the safety switches to see if you is shorted out due to the power washing you gave it. I had a Dodge Minivan that I gave a good power washing to and then it wouldn't start. After pulling my hair out, I towed it to the dealer and left it. A few days later they tried it and it started right up. It took several days to dry out. I never power washed it again. Let us know what you find.
Thank again for all your advise. I have the problem solved, after a week of checking anything I could according to the WSM. I traced it to a harness on which some things did not work. When I turned the ignition on, the horn went. I thought there must be a cross connection somewhere, but where? I did need to dismantle the dashboard and steering column to remove the fuel tank for repairs, so there must be something I did wrong in there. I felt under the dash to find any loose connections. Couldn't feel anything. I managed to pull out two harnesses, to look at them. Well I thought, they were both eight pin, ie identical. Someone as stupid as me would put the wrong harnesses together.
I swapped them over, and all my problems were solved. I usually mark connections for identification, but not this one. The moral of the story is, MARK ALL CONNECTORS WHEN DISMANTLING.
ozzie
