PTO Safety Covers
Southern Yankee
L3301 HST, Front Loader. Land Pride Brush-Hog, Box Blade, and Quick Hitch
May 21, 2016
46
Wellston, Oklahoma
Ramos and Pat, thank you for your inputs. I did not mean to offend. At the time, I looked at the identity sidebar and we are all apprentices. I guess, like Trump, tact and fineness is not one of my better traits.
Pat, you are right, back in the late forties, my uncle was a real farmer and he had a little finger missing (hay baler. I believe). I had my first farm incident with him. I sat on the brake release of his Farmall MD and it started rolling down the driveway. I think I was six or seven at the time.
Believe me, in both the military (aircraft maintenance) and my civilian job (industrial specialist) we breathed safety. However, my old body (I’m 75) and hands do not move like a young persons and I find the PTO bell cover to be a poor design (at least for me). I know from experience some manufacturers will do the minimum to comply. To me the ideal would be a spring-loaded bell cover that slipped back into place after the lock ring was moved. I realize the objective of the safety covers is to protect the stupid (and I can sometimes be that way) but there is a lot of overkill and poor design out there.
The purpose of my post was to find out if there is a better way to do things. Is there a better after-market product or a way the bell cover can be modified and still perform its function. My first thought was to remove the bell cover and leave the inner cover. Someone mentioned trimming the bell cover and I wonder if the sides could be cut out of the bell cover to reach the slip ring and have the cover still perform its function. I am a newbie, I don’t know if there is a better way and that is why I ask. I am getting some good inputs and an education and I thank you all for that
Richard
Southern Yankee
May 21, 2016
46
Wellston, Oklahoma
Look at Bare PTO guards or learn how to disconnect your cover from the bearings to pull it back out of the way
http://www.bare-co.com/files-pto2002-selsafety
Russell,
Have you every seen one of these covers? Do they slip on or mount easily?
By the way, my son lives near you in Dripping Springs. Austin is a hard town to drive.
Richard
1970cs
1,124
Grand Ledge
Most real farmers have insurance inspectors and minimum wage employees.
I am in construction, so the safety stuff stays on the company equipment.
At home, only me and my daughters operate the tractor. I got tried of trying to reach the grease fitting on the cv joint on that new $13000 bush hog and cut the guard off. It's easy now. I don't see how that pto shaft can hurt me. I have spent countless hours waiting for the blades to stop turning to adjust something.
The girls are learning to drive so they use the seat belt and will not get off that seat unless its on fire, I am there, or everything quits spinning.
I learned all this on a tractor that had no ROPS and do seat belt over 40 years ago and still have all my fingers and toes.
You can defend all you want. It's still not safe! Like I said, do what you want it's your life and your family!
Pat
1970cs
1,124
Grand Ledge
Richard
No big shakes here!:cool: My intentions here is to help and inform people of anything that I can truly help with in my 22+ years experience at my dealership and 3 years at a rental store.
The last thing I want to see is someone getting hurt or worse killed.
This is why you see so many stickers caution rotating, pinch point, flammable and hot. It's because someone got hurt or killed and the lawyers get involved.
Pat
3,093
Russell,
Richard
Yes I own one. Bought it for a shaft with no cover. They have pop open snap handles so you can get the guards out of your way when connecting or disconnecting the PTO shaft. I still have to use a screwdriver to pop it open but it may loosen up over time.
On another shield I just have to turn a couple of plastic screw heads and slide the shield out of the way. This style is a bit more difficult to get back together.
It's a small world, I grew up near Dripping Springs, in a small place called Driftwood. Went to school in Dripping Springs.
Austin does have poor traffic patterns.
