Head lights and tail lights don't work
Drbobdc
L2900gst
Nov 4, 2016
Arroyo Grande, ca, usa
I have a L2900 GST The headlights and tail lights don't work the hazard lights do work and all my gauges and dash lights work tried to test the switch voltage coming in but it seems like no we're going out I don't know what is normal or if this could be a relay issue ?
2,581
Chances of all bulbs being bad are slim.....gotta be a open circuit somewhere, bad wire, fuse - loose connection.
I am betting fuse is bad.
but if not,
If you have an OHM meter - take a small straight pin and attached to one of the leads (POS) and then you can prick through the insulation at specific points along a wire and see if a wire is broken - and also check for voltage at the lights too.
6,710
Check your quick connects around your dash as well. Dad was having an issue with his l2250 doing the same thing.
Found corrosion in one of the quick connects. After spraying with contact cleaner and cleaning the pins, they started working again.
