Grey market FEL on L1-24 Sunshine
Crazy Horse
L2950
Oct 16, 2016
67
Graham Wa U.S.A.
Hi guys, I recently purchased an l2550 tractor with a front end loader on it, I'm looking for info about the loader, as everything on it is in Japanese. The local dealership won't help me, as they informed me it's a gray market machine.
Any ideas about how to find out who made it, if it's factory or not, or info about parts, specifically a control valve for it?
8,743
Re: Front end loaders
Post some pictures of what you have. ;)
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Crazy Horse. Glad you joined us here. If anyone can help you it is the Wolfman.
Crazy Horse
L2950
Oct 16, 2016
67
Graham Wa U.S.A.
Ok, here's a few pictures. The issue I'm having is that it will go up but is very slow letting it down, and also it will dump but not pick the bucket back up very fast. I already changed the hydraulic filter at the suggestion of a friend, whom also suggested changing the control valve, thanks.
8,743
Ok the good news, it's a Kubota loader.
Now the bad news, it isn't a Kubota loader normally seen or used in North America, and getting parts or any information is going to be near impossible.
Now what is the problem with it?
You mentioned control valve, is the valve bad and you need to replace it?
If so then any open center 8 GPM or close valve will work.
Here is one example:
http://www.ebay.com/itm/2-SPOOL-10-GPM-COMPACT-HYDRAULIC-JOYSTICK-CONTROL-VALVE-BRAND-LV22RFSTKAB-9-7401-/171524385553?hash=item27efa66b11:g:3p8AAOxy63FS79wc
Crazy Horse
L2950
Oct 16, 2016
67
Graham Wa U.S.A.
Thanks Wolfman, another thing I noticed and did is I took the cap located in front of the seat off and hydraulic fluid came gushing out. I drained off about 8 gallons and it's still over the full indicator window. Is the window relevant if the loader was added to the tractor after manufacture? The fluid looks fine, should I completely drain it and add only the prescribed level, which is 7 gallons?
Crazy Horse
L2950
Oct 16, 2016
67
Graham Wa U.S.A.
Also, thanks for the valve info.
8,743
Yes I would drain all of it out and replace it with new, and do the filters at the same time.
There is no logical reason it should be over full even with the loader on it. ;)
torch
Jun 10, 2016
2,734
955
Muskoka, Ont.
I can't see if there is a separate pump for the loader, but if not, wouldn't he need a spool valve set with power beyond? Here's the same one as above, but with power beyond for only $10 more:
http://www.ebay.com/itm/361099372795
(It's the one I bought for my loader. Currently under construction so I can't tell you if the valve is actually any good or not yet...)
8,743
You could have saved yourself $10 as you don't need power beyond either, you only need in and out. ;)
But good catch on his, Would need to know if it's a 2 hose or three hose model.
Just so you know, the power beyond allows you to use both the loader and the three point at the same exact time, I really don't see that as being an issue with the B6100.
torch
Jun 10, 2016
2,734
955
Muskoka, Ont.
With respect, I think I do need the power beyond option. From the WSM:
The implement pressure control valve (5 ) must be a type which will return oil relieved by the relief valve directly to the transmission case . If the valve is a type which returns oil to the return pipe (7), when the three-point linkage system is operated simultaneously with the hydraulic block, the three-point linkage-side relief pressure and block-side relief pressure will be added together and the gear pump and other units may be damaged.
According to the data published by Brand Hydraulics (the manufacturer of that control), without the power beyond option the relief valve dumps to the outlet port -- exactly the scenario that Kubota warns against in the WSM.
However installing the power beyond cartridge in the outlet port redirects the relief valve discharge to the "optional outlet port" ie: the low pressure tank return port.
Your way would work 99.9% of the time. It's that 0.1% that would bite me in the @$$. I'd be lifting something with the FEL and somehow bump the 3ph lever and blow up my hydraulics. $10 is cheap insurance.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
Can I ask a question?
Maybe it was covered already, but which way do you operate joystick to dump, amd which way to raise the loader?
If you pull lever to left, that should be curl, and move to right would dump.
If you move lever up, that should lower boom and if you pull lever straight down, that should raise boom.
If you have a set crossed, you could be fighting a regenerative feature, that may or may not be present in valve?
6,623
I think the valve you guys (Torch and North Idaho Wolfman) are discussing is the same valve with the only difference is the price.
Both valves have this in the description, "Optional conversion plug for closed center only operation sold separately. You can also simply plug the power beyond port to close the center on this valve."
torch
Jun 10, 2016
2,734
955
Muskoka, Ont.
Both are the same basic unit, but look at the title of the one I linked -- "w power beyond". I bought that control, it's sitting on my workbench right now and I can assure you it came with the power beyond option installed.
