What Hodge said, i designed a set of jacks for a trailer, spring loaded pin that releases with a 1/2" turn. Because pin is on a spring it wont drop the leg in travel like a threaded clamping bolt.
Not to mention the threats upon lives such vandalism can cause.To think people would want to cause that type of wanton destruction. I've got a lock on my pin just cause I don't want people to steal my $50 ball! I'll keep a closer eye on my setup. Good advice.
Yes it's a very good habit to get into no mater what angle its at.Should I always be putting something under the rear of the trailer when loading or unloading the tractor.
When you load the trailer....do it on flat ground, or near flat ground.So educate me a little since I just bought a 16’ tandem axle trailer to haul my BX2360 on. I’m a tractor hauling noob.
I have a 2011 Ford F-150 4x4 with a small 2” lift on it. My trailer has the fold down gate for loading. Should I always be putting something under the rear of the trailer when loading or unloading the tractor or is it only necessary if I’m on a hill? I do put wheel chocks under the trailer tires. I don’t want something like this happening to me.
Thanks.
I had a hot shot driver do that to his 1 ton dually down in San Antonia Guy contracted to haul a 16,000lb rated forklift up to Midland. Asked the guy if he wanted to block the goose neck trailer. He said nope, it will handle it. Asked him if he was sure?. He said load it.Yes it's a very good habit to get into no mater what angle its at.
A couple wood blocks will do wonders.
It's also much better on the trucks suspension.
I once was on a job and this guy was bragging about how his truck could haul so much weight, he was hauling a mini ex at the time, they back it off on flat ground, and it pulled the back of the truck off the ground and proceeded to blow his air bags to shreds, he had a hard time just pulling the empty trailer off the job.
First off, this was NOT me. I always put jack stands under the rear of the trailer to keep it from lifting the truck up.
A guy was unloading a kubota, while parked on a hill. This raised the rear of the truck enough that it started going down hill and crashed in to a house.
http://akvnews.com/truck-hits-house-in-apollo-borough-crash/
hoping the operator and home owners are all OK
3 weeks ago a Zagray's (Colchester Ct) May show we watched a teenager try to load a 20hp-300-400# garden tractor up hill. Ramps were slippery metal diamond plate. After first try failed, he backed up, gunned it in 2nd gear and rolled it backwards right over himself. Thought he broke his neck or back. After a few minutes he got up. Always load slow, flat if you can, chock front wheels on hills, and support trailer deck if the tongue lifts up. Or pay up your life insurance. When it doesn't work, its talkin to you. LISTEN!Wow good reminder to everyone how quickly things can go wrong. I had close call one time but backed off before it got away.
One time cutting wood in the winter I parked the truck on a hill in the field got out started cutting turned around and the truck was sliding down the hill. It stopped before it hit anything but sure got my attention.
